mario73
Nov 27, 2018Aspirant
Problem with Remote Management orbi rbr40
when i try to select remote managementi get an error message:an occured while activating remote magagement.
Nov 27, 2018Guru - Experienced User
What FW is currently loaded?
Is the error appearing on the Orbi app or on the routers web page in a browser?
mario73
fw v.2.2.1.210
fatweb modem dv 2200
in the app of ipad, while in android app it's not possible the configuration because after that i have selected management remote i'm direct to the page of userid and password
this problem is new, few day ago was ok
- FURRYe38Nov 27, 2018Guru - Experienced User
Can you enabled it using a PC and browser connected to the routers web page?
- mario73Nov 27, 2018Aspirant
ii tried but not function
Tried but it didn't enable it?
What browser are you using?
I would check your modem as well. I believe it has built in router and wifi already:
Modem Combo Units:
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
