cmh75
Aug 19, 2018Aspirant
Problems Streaming Media Files from NAS
At present I can access my NAS from my media player and play media files without any fuss. Unfortunately the movies will all freeze at some random time usually between 2-15 minutes. Once frozen, the only way out is to power down the media player. This problem has never occurred prior to the Orbi RBK50 that I recently setup.
I'm running the latest firmware at 2.1.4.16. The NAS is a wired connection to the router. The media player is a wired connection to the satellite.
So far, all Netgear phone support has had me do is change the MTU size from 1500 to 1450.
I'm certainly open to any suggestions. Thanks in advance for any advice.
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).Change MTU back to 1500 if your on a cable connection. MTU only effects WAN side connections.
What is the ISP mfr and model#?
Does the stream work if you connect it and the NAS directly to the back of the base router?
- cmh75AspirantSorry, I should have added that the satellite and router are also connected via Ethernet cable.
Any network ethernet switching in between?
- cmh75Aspirant
Sorry I have taken so long to reply, but i have not had time until recently to play around with the setup.
The problem continues. The Orbi functions perfectly for everything I need except the streaming of media files from my NAS. They play for a variable time and then just freeze.
I have tried connecting both to the base router but this makes no difference. I know the beyonwiz pvr media player might be the culprit, but it works perfectly when connected to my telstra modem/router, just not the orbi.
Thanks for any advice or help.
I see that when you initally posted you were on v16. Has the system FW been updated to v210? If not, you might manually load this FW to the sateliltes first then router, then do a factory reset and setup from scratch.
Modem Combo Units:
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktopCan you configure the router for option 3 and see if when connecting the NAS to the back of the Orbi router continues to exibit this issue?
Can you stream from a different device like a PC from the NAS?
