rhett7660
Sep 07, 2018Aspirant
Problems with AP mode but DHCP is still ON
Hello,
I have my Orbi setup in AP mode however the settings are still showing DHCP has ON. I have gone in and switched it back to "Router" mode, gone back under the Setup-LAN Setup and unchecked the DHCP. Then went back and switched it to AP mode and DHCP comes back on. How do I disable the DHCP on this device for AP mode?
I have the following:
Verizon FiOS-G1100 - Handleing the DHCP
Orbi BRB40 - I want to be in bridge mode only, not handling the DHCP
Orbi Firmware Version: V2.1.4.16
Any help on this? I have restared both the Verizon and the Orbi several times and have also reset the Orbi to factory and resetup.
Mine does, yes. It evidently means DHCP client mode, not DHCP server mode. As in AP mode with dynamic IP versus fixed IP.
Unless the OP has indication the Orbi is handing out DHCP addresses in AP mode (which it does not do), there is nothing to be concerned about.
- rhett7660Aspirant
Also, I have the wifi turned off on the Verizon.
So do a factory reset on the RBR, setup from scratch. Go in and set the AP mode setting. Apply and reboot. Do this while the RBR is not connected to anything accept for 1 wired PC.Reboot the PC or disconnect the LAN cable from the RBR for 10 seconds then plug it back in. After making the change and the RBR reboots, does the wired PC get a IP address after it reboots? It shouldn't. If it still does, then you may have a bad system and would need to contact NG support and ask for a replacement.
