orbfusion
Mar 05, 2017Aspirant
Problems with install - TV right next to satellite is very slow and won't stream HD
Hello. I installed Orbi yesterday to upgrade from an airport extreme. I have the base unit in the living room and the satellite in the office. My home is shaped like an "L", with the outside bott...
st_shaw
Mar 06, 2017Master
If your TV has a wired Ethernet connection, you should really be using that to stream video. Best to wire the TV to the router. If that's not possible, then wire the TV to the Orbi satellite.
You problem with wireless could be that the Orbi is too close to the TV. Move them apart and see if that helps. But, like I said you should wire the TV. This will give better performance for the TV and everything else on your WiFi network.
