thunderdragon
Nov 11, 2018Follower
product already registered
so sounds like I have run into a common problem with the router being already registard, so to start off with I dislike the way you have your support process set up I dont like hanging my information...
michaelkenward
Nov 12, 2018Guru - Experienced User
thunderdragon wrote:
I dont like hanging my information out for everyone to see.
I have no idea what that is all about. Or where you are asked to share your innermost with the world.
This "can't register" issue comes up almost daily. Had you take the trouble to research it here you would have discovered that the usual response is to get in touch with a Netgear moderator, someone like DarrenM, with a private message.
