robsquatch
Dec 13, 2018Tutor
Purchased two mesh kits - Can I convert second router to satellite?
Hello,
I purchased the RBK22 system from Costco, then decided to replace it with the RBK43 system from Best Buy for more coverage. However, I quickly figured out I could use the extra satellit...
robsquatch
Dec 13, 2018Tutor
This router is already in AP mode because I used my FIOS for routing instead. As it sits, it should be able to be added as an AP? Will it have the same SSID and work seamlessly like the rest of my system already does? Or does it need a unique SSID?
Dec 13, 2018Guru - Experienced User
It could have the same SSID however you would need to make sure the 2.4Ghz and 5Ghz channels are not the same. If you have one set for channel 1, the other one needs to be set for channel 11, Set 5Ghz to 36 and the other one to 48. Ensure the two are placed as far appart as possible. 30 feet to start. Again the 2nd RBR in AP mode will not be appart of the 1st MESH system, Will just a a separate wifi source is all. If you encounter problems, besure to turn off this AP for troubleshooting.
