Marcvn's avatar
Marcvn
Purple ring on satellite when adding a net work cable
Hi all,
been looking around and could not see anything, so apologies if this is answered. Prior to firmware update V2.7.2.104 which I got given last week, my entire setup worked fine with the router in AP mode (connected to broadband router in yellow port) and the satellites connected individually through the house. One of the satellites had all 4 ethernet ports in use and no issues ever occured.
Now with the new firmware update, 2 of my satellites go purple when certain items get connected.
For example, my satellite has got my hue bridge and chromecast connected via ethernet without issue. If I then plug the sky box in, it puts the satellite into permanent purple ring mode.
I have factory reset everything including sky box. I also tried the same cable on other items plugged in and no issue there.
I can't see anything different in my setup to have caused this, but I might be missing something obvious.
If I can avoid it, I would rather nto revert firmware versions, but starting to wonder if that is the best way forward.
Any help would be greatly appreciated.
Marc
  • Marcvn wrote:
    Hi Marc
    Let me be the first to say, when I read this..."Prior to firmware update V2.7.2.104 which I got given last week, my entire setup worked fine with the router in AP mode (connected to broadband router in yellow port) and the satellites connected individually through the house. One of the satellites had all 4 ethernet ports in use and no issues ever occured."
    There are several posts in here about the problems with firmware updates.  Several folks in here will respond to your question here by asking you a dozen questions and having you jump through a 100 hoops.  My recommendation is that as much as a pain as it might appear, your best option may be to revert the firmware.
    Of course the choice is yours and if you feel like you got a day to devote to troubleshooting, go for it.  Understanding that even after all of that your system may still not work correctly.
    Good luck.
    • Marcvn's avatar
      Marcvn
      Thanks for the reply.
      Thought I had managed to solve it whenI noticed the guest network was broadcasting but no luck. Looks like I might have to revert to old firmware today and see how it goes
      • vajim's avatar
        vajim
        Master
        Thanks
        If you do revert, perhaps you can share your expereince.  I imagine there are lots of folks in the same boat with firmware issues.
