Brenkj
Feb 22, 2019Aspirant
Putting Modem in Bridge Mode for Orbi Installation
I just got my new Orbi RBK50, and I'm getting ready to install it. I've found instructions online for how to put my ATT-provided modem into "bridge mode", so that the Orbi will be the only device b...
Chuck_M
Feb 22, 2019Mentor
Do that before installing.
And to be precise, you have a modem/router combination.
Bridging it will turn off the router functions and pass through to the Orbi to handle routing.
Bridge it
Power off
Connect Orbi
Power on Modem, Orbi and PC
Set up (hard wired ethernet if possible)
Enjoy
Brenkj
Thanks for the responses. I did all those steps, in that order, but the Orbi app is saying there is no internet connection, and that an Ethernet cable cannot be detected. Any advice?
- FURRYe38Feb 22, 2019Guru - Experienced User
Try setting up the Orbi first with a PC or laptop thats connected to the Orbi router.
Brenkj wrote:
Thanks for the responses. I did all those steps, in that order, but the Orbi app is saying there is no internet connection, and that an Ethernet cable cannot be detected. Any advice?- CrimpOnFeb 22, 2019Guru - Experienced User
Is the Orbi connected to the ISP modem using an Ethernet cable from the WAN (Yellow) Ethernet plug on the Orbi to "Port 1" on the ISP modem? If it is, then I would first try a different Ethernet cable.
- BrenkjFeb 22, 2019AspirantOkay, will do. Where should the cable be connected on the modem? I have 4 ports marked “Ethernet,” and one marked “DSL Broadband,” but the cable included with the Orbi doesn’t fit in that one port. Thanks
- ekhalilFeb 22, 2019Master
Brenkj wrote:
Okay, will do. Where should the cable be connected on the modem? I have 4 ports marked “Ethernet,” and one marked “DSL Broadband,” but the cable included with the Orbi doesn’t fit in that one port. ThanksIt should go to one of the 4 "Ethernet" or LAN ports on the modem. Since the modem is bridged please try the one marked 1 first.
Brenkj wrote:
Thanks for the responses. I did all those steps, in that order, but the Orbi app is saying there is no internet connection, and that an Ethernet cable cannot be detected. Any advice?Can it be a bad cable that connected between Orbi and the ATT router? Is the cable connected to the yellow WAN port in the Orbi router?
