john-iv
Sep 28, 2016Follower
[Q] Possible to remotely reboot the Orbi Satellite?
Hello, in the admin web site I see where to reboot the router, but is there an option to reboot the satellite remotely? Thanks -
itGeeks
Sep 29, 2016Apprentice
This is just a guess but it makes sence that when you send a reboot comand it reboots the entire Orbi system, Maybe someone can confirm?
- DarrenMSep 30, 2016Sr. NETGEAR Moderator
I have tested this when rebooting the router the satellite does not technically reset but it does resync back up to the base which is the main router that handles everything so as long as the satellite is syncing back up it should be fine.
DarrenM
