MightyT
Jul 06, 2018Star
QOS on RBR50
I am perplexed about the QOS setting having nothing more than a Speed Test button? Is it me? How are we suppose to assign priority?
st_shaw
Jul 06, 2018Master
Jeremyinsf wrote:
http://orbilogin.net/QOS_main.htm
Have you tested your router to see if the settings on this hidden page actually work?
Jeremyinsf
Jul 07, 2018Apprentice
I'm not currently using it as I have 1Gb symetric fiber and that's far more than I need to use, let alone prioritize.
However, when I was on DSL previously and needed to share limited speeds with voip and vpn, it seemed to help.
Do you have indication that it does... nothing?
- st_shawJul 07, 2018Master
No. In my testing, the non-hidden QoS page seems to do nothing, so it would be odd for this hidden QoS page to work.
I have not tested this hidden page myself, and I have never seen a post from anyone who has tested it. However, there are many posts on here wanting QoS, so it would be good to know if this actually works.
I use a third party router, so I don’t currently need QoS on Orbi either.
- Cmo1Jul 07, 2018Apprentice
The QOS is basically broken and does nothing. It's one of about 10 things I wish netgear would fix. They either employ really dumb engineers or just plain don't care.
