rhill1959's avatar
rhill1959
QoS Setup Orbi RBR850
I just got the Orbi RBR850.  So far I like it.  My question is about the QoS Setup.  I read in an older post for a different Orbi model that you can't adjust the settings.
https://community.netgear.com/t5/Orbi/How-do-I-configure-QoS-settings-on-Orbi-RBR50-router/td-p/1813567
I didn't turn on this feature and all I see on the panel is to do the speed test.  My question:  Is the Orbi RBR850 defaulted to always have this on, or can it be turned off?
Thanks,
Robert
  • Mstrbig's avatar
    Mstrbig
    Aug 21, 2020
    rhill1959 wrote:
    Thanks for the reply.  I haven't found a switch within the Orbi panels.  Do you know where to look?  Seems like it's an always on feature.
    Are you using the app or orbilogon.com?
    Under orbilogon.com / Advanced / Advanced Setup / Wireless Setup / Check or uncheck "Enable WMM (Wi-Fi multimedia) settings"
  • You should be able to turn it off. Arguably I find it better on, when doing speed tests. It works for my streaming devices, but I may suffer some speed loss on others. But who really knows as speed tests can be different each time you do one.
    • rhill1959's avatar
      rhill1959
      • Mstrbig's avatar
        Mstrbig
        Master
