kick60's avatar
kick60
Tutor
Oct 30, 2018
Quel Satellite additionnel pour RBK40 ...
Bonjour,
Je possède un kit RBK40-100PES, qui est composé du routeur RBR40 et d'un sattelite RBS40.
Je souhaite etendre mon réseau, suis-je "Obligé" de mettre un autre sattelite RBS40-100PES,
Ou puis-je mettre un sattelite additionnel RBS20-100PS ? Est-il 100% compatible avec le routeur RBR40 ?
Je ne trouve cette info nulle part,
Merci d'avance de votre aide à tous
Cristofe
  • FURRYe38's avatar
    Oui.
    veuillez utiliser l'anglais. Je vous remercie.
  • Hello,
    I own a kit RBK40-100PES, which is composed of the router RBR40 and a sattelite RBS40.
    I want to extend my network, am I "obliged" to put another sattelite RBS40-100PES,
    Where can I put an additional sattelite RBS20-100PS? Is it 100% compatible with the RBR40 router?
    I can not find this info anywhere
    Thank you in advance for your help to all
    Cristofe
    • FURRYe38's avatar
      I believe you can use a RBS20 with the RBR40.
      30 feet is recommended in between base router and satellite to begin with depending upon building materials.
      I recommend contacting NG support in your region to confirm that the RBS will work for you.
    • ekhalil's avatar
      ekhalil
      Master
      RBS20, RBS40 and RBW30 should be compatible with RBR40, as all these devices are AC2200 (2x2 backhaul).
