mcgunner
Oct 01, 2018Aspirant
R8000 to ORBI RBR40
Have R8000 for personal activities with rbr40 connected. ORBI drooping signal and will not synch with satellite.
mcgunner
What is FW?
Modem is Arris SB8200 (owned).
Yes. R8000 wifi disabled. Don't know if the Orbi is running in AP (?) mode. How do I find out?
House is approx 1800 sq ft.
Satellite is approx 25 ft from Orbi.
Not tech savy regarding channels. How do I find out? Are you referring to the Orbi or Nighthawk?
One wifi neighbor within 50 yards.
How do I disable any of the things you are referring to? Are you referring to the Orbi or Nighthawk?
I do know how to save and reboot.
Thanks.
mcgunner
What is FW?
Orbi is now running in AP mode.
Disabled all of the things you referred to.
I
- FURRYe38Oct 02, 2018Guru - Experienced User
FW = Firmware.
Use a wifi scanner to see whos around you and using channels.
You can set your Orbi channels on the Advanced Tab/Wireless settings.
- mcgunnerOct 02, 2018Aspirant
Followed all your advice except for the changing channels, and everything worked really good for the whole evening last night. Then I had to leave early this morning and got home about 1600. Roommate informs me has had no internet all day even though iPad indicates it is using ORBI. Had to re-sync satellite. Not sure what is going on.
Question: Can I set this system up in the reverse; modem to ORBI to Nighthawk? This would make the ORBI the dominant router with Nighthawk as an AP. Then could I still use the printers hard wired USB to the Nighthawk? And could I make them shared printers so all computers can use them? Only one is wireless.
Yes, however you wouldn't need the Nighthawk router if you used the Orbi in router mode in place of the R8000 router. Which would be recommended...
