rinku2012
Nov 22, 2017Tutor
R8500 with Orbi
Hello, i am staying in 3 floored townhome. Currently i have Netgear R8500 AC5300 router. I have placed the router in 2nd floor. I am getting good internet speeds with 5ghz connection in my 1st, 2...
RogerSC
Nov 23, 2017Virtuoso
Hi. I would keep the R8500 in router mode as you say, and turn off the wireless radios on the R8500. Then connect the R8500 to the Orbi and put the Orbi in AP mode:
https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point
I have my R7800 and Orbi configured this way and it works well for me.
Good luck!
rinku2012
Nov 23, 2017Tutor
Hello,
Thanks for the reply. can you let me know on how can i turn off the wireless radios on R8500 ?
- RogerSCNov 23, 2017Virtuoso
I don't have an R8500, but if it uses roughly the same admin web interface as the R7800, you would go into the admin web interface. If you don't know how to do that, you can either use the owner's guide for the router (downloadable from Netgear), or use "192.168.1.1" in your browser's address bar (where "192.168.1.1" represents the IP address of your router, that one's just the factory default address, and most people use that IP address). If you haven't changed the admin web interface password, the credentials are "admin" / "password". Then, click on the "ADVANCED" tab and "Advanced Setup" on the menu on the left. Then click on "Wireless Settings", and uncheck the "Enable Radio" checkboxes for 2.4GHz. and 5GHz. bands. Then when you go back to the main "ADVANCED" tab, you should see that the wireless radios are turned off.
I may not have the details entirely correct for your router, but what I have above should be close enough to get you there. If the above isn't good enough, you can download the user's manual from Netgear, and that should also tell you how to disable the wireless radios.
- rinku2012Nov 23, 2017Tutor
Hello,
I saw the documentation and validate don how to turn of the radios on the R8500.
Presently i have 2 SSIDS ( 1 for 2.4 ghz and other 2 combined for 5 ghz). once i disable wifi radios and enable AP on orbi should i use the same ssids which i use on R8500 so that there wont be any disconnect of internet on my home devices (I have more then 45 devices connected in my home).
after i do this setup my R8500 serves as main router and can i manage the settings like Mac id clone, port forwarding, QOS etc on my router ?
Once i keep orbi in AP mode, should i need to change any more settings in there ?
Once again thanks for your response
Oh my god, lost another full reply somehow, what horrible forum software!
Personally, I use the single SSID that the Orbi provides. Since I want all my clients on 5GHz., it's pretty easy for me, that's what the Orbi does here, puts all my clients on 5GHz band. But if you try the single SSID, and you can't live with the way that the Orbi sorts out your clients between 2.4GHz. and 5GHz. bands, you can search the forum here for how to have a 2.4GHz. SSID and a 5GHz. SSID. Not hard to do, but you have to follow instructions carefully, and you'll need use telnet to get it done. I would strongly suggest using the single SSID first, though, and see if that works for you...it will simplify your life considerably *smile*.
Yes, you'll set up all your routing configuration in the R8500. There are few settings in the Orbi in AP mode, but I'd recommend going through them so that you know what's there. There's some useful stuff there, like wireless settings and the usual "Attached Devices" listing that can be informative. Yes, QoS and so on are managed on the R8500.
One thing to keep in mind is that there are two ways to get to the Orbi router unit web admin interface once it's in AP mode:
1. Use "orbilogin.com" or "orbilogin.net" from a client that's connected to the Orbi wireless or directly plugged into a LAN port on the Orbi router or satellite.
2. Use the IP address of the Orbi router unit (available in "Attached Devices" in the R8500). You can get to the Orbi satellite unit the same way, using it's IP address that you get from the R8500 "Attached Devices" list.
This really is pretty easy once you have it all set up. And it works really well.
