passdj2002
Sep 28, 2017Guide
Radio Transmit Power control new firmware
I just done the firmware upgrade but I still cannot control the radio transmit power.. anyone can help me with this issue?
- Sep 29, 2017
passdj2002 unfortunately the ability to turn off a particular radio completely off is not available in many threads this feature and ability and option to do so has been discussed and requested. the ability to adjust radio power was just recently re added back for a while that option was taken away top...best u can do now is set the 2.4GHz to 25% can't turn I off completely as of this moment maybe in a future Firmware it may be an option.
martyfp
Sep 28, 2017Luminary
You need version 2.0.0.72 or .74
The power control is in the Advanced Settings, under Advanced Setup/Wireless Settings.
You should see separate "Transmit Power Control" settings for 2.4 and 5GHz.
- passdj2002Sep 28, 2017Guide
here's my settings (sorry they are in italian) I don't have transmit power control..
- Steven_BelfastSep 28, 2017ApprenticeThe image you posted shows the option for transmit power control both on 100%
- JMU1998Sep 28, 2017Luminary
passdj2002 click on the down arrow to see options for 75%, 50%, 25% radio power adjustment selection options
Ok I understand.. but if I want to transmit wifi only in 5ghz what I have to do to stop the transmission of the 2.4ghz signal?
