mad153
May 07, 2020Follower
random disconnects and slow downs
hello!
I recently purchased my first orbi system: RBR50 and RBS50 satellite. My experience so far has not been good. My devices randomly get kicked off the network (a firmware update did help) and i can't remember the last time i got the speeds on wifi that i get plugged in via ethernet.
I know wifi is able to get me those speeds (68 - 72 down 15 up) because my ISP router could do it, but it could only support 20 devices.
Currently i have 32 devices connected and both the router and satellite is running V2.5.1.16. Most of the time my devices get 20 - 30 down, even though a speedtest on the orbi router's website (orbilogin.net), shows that i get the minimium 68 down i pay for.
I have turned on Implicit beamforming but this has not really helped.
My Backhaul status is reported as "GOOD".
thanks for the help!
1 Reply
Is the Orbi system operating in Router or AP mode?What is the size of your home? Sq Ft?
What is the distance between the router and satellite(s)? 30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-routerWhat channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many?Try enabling Beamforming and MIMO(MIMO may or maynot be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s).Has a factory reset and setup from scratch been performed since last update?
Modem Combo Units: https://community.netgear.com/t5/Cable-Modems-Routers/What-s-the-Difference-Between-a-Cable-Modem-and-Cable-Modem/m-p/1864698#M21950
This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
https://kb.netgear.com/26765/Disabled-Features-on-the-Router-when-set-to-AP-Mode
