fade0508
Apr 16, 2018Aspirant
RB40 not working in AP mode with virgin HUB 3.0
Hi, Apologies if this has been covered elsewhere but I could not find a thread that addresses the problem/challenge/issue. I recently installed Virgin Media Hub 3.0 and to improve coverage ...
Apr 16, 2018Guru - Experienced User
Besure to use the DMZ on the ISP modem if you run the modem in router mode with the Orbi router in router mode. DMZ helps in this kind of double NAT configuration.
