scottmph's avatar
scottmph
RB50 Suddenly blocking my sites
so this morning Orbi has decided to block all my personal sites and my VPS signin to WHM with leaseweb
It happens on any divice I use that uses the wifi.
I can get if I go through my vpn at work and on my phone if i discoinnect from Orbi
I set dns as google and no change. This is maddening. Anyone have same in past?
  • CrimpOn's avatar
    CrimpOn
    Nothing changed on the Orbi?  No new firmware?
    Is Armor and/or Disney Circle activated?
    • FURRYe38's avatar
      Armor, Circle. Save settings and reboot the router and satellite(s).
      Pal2999 wrote:
      Having the same problem
      • Pal2999's avatar
        Pal2999
        Firmware V2.5.1.16
        Virgin media router in modem mode
        Circle disabled I don’t have armour
