DoomGirDoom
Jun 30, 2021Follower
Rb50 wifi password works for minutes then stops on some devices
- HopefullyI set that up correctlyBecause my orbee will not keep the password As Correct For Certain Devices. For some reason only my computer, my Echo show 5 and Galaxy S21 Ultra Are Having Issues. My LaptOp Is connected by LAN, I Don't Know what to do because I can't seem to find this enable Smart Connect which seems to be one solution I found but I can't find The Option For It Anywhere. And I've gone through pretty much every single Option. And I don't know why exactly my cell phone right now is actually Capitalizing random letters. And the weird thing about it is that I didn't even touch the damn thing and settings in the past little while and it's just suddenly doing it. just randomly is about 3-5 days ago it just started not accepting the password
1 Reply
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?What browser are you using to manage the RBR?
Try setting a simple alphacharacter PW, 8 characters on the RBR.
