routerks's avatar
Nov 17, 2020
RBK 13 connect to Printer
Hi,
I have new RBK13 Orbi Wifi system and would like to know the process of connecting this to my Canon printer which needs WPS.
Thanks in advance for any suggestions or workaround to connect.
Kiran
  • FURRYe38's avatar
    Have the printer connect to the SSID name and PW set on the RBR for wifi?
    Please contact the mfr for help and support information regarding there product.
    • routerks's avatar
      routerks
      Tutor
      Thank you very much for the response. I will try this option.
    1. Remove ALL security from my WiFi network.
    2. Use WPS to connect the two.
    3. Check ORBI webpage and ensure that printer shows up as a device.
    4. Go directly to the IP address of printer noted in 3.
    5. Logon directly to printer interface d - password was in the manual.
    6. Manually enter the SSID and password.
