nicholasbc
Aug 15, 2022Aspirant
Rbk 14 firmware upgrade file corruption.
RBK14 firmware upgrade problem when I download the latest router, and satellite firmware files, and try to unzip them, I get a message, that the file is corrupted. This is before even trying to upg...
CrimpOn
Aug 16, 2022Guru - Experienced User
Sometimes, "shit happens". (Forest Gump) Try downloading and unzipping again?
Just as an aside, over half the times I attempt to update Google Chrome, the update downloads and then claims "file corrupted". When I update the second time, it works.
- michaelkenwardAug 16, 2022Guru - Experienced User
Good thinking.
Just tried it. Nothing went wrong when unzipping the file.
RBR10 / RBS10 Firmware Version 2.7.4.24 | Answer | NETGEAR Support
That's the one that comes up when you look for the RBK14.
