EGold
Feb 18, 2021Follower
RBK 50 Wifi speed is 35mbps while ethernet speed is 500mbps
I cannot figure out why the wifi speed of my orbi RBK50 is 25-30mbps, when the RBK50 ethernet speed is 500mbps; the Xfinity routers ethernet speed is 500mbps the Xfintiy wifi speed is 150mbps. The Orbi's speed is paltry in comparrison. I have tried everything. I am so dissappointed in the is product, I am ready to toss it out.
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too? If your ISP Modem already has a build in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop - vajimMaster
finity routers?
