rebknell's avatar
rebknell
RBK20 bought used - previous owner did not reset
Hello all,
I bought an Orbi RBK 20 on eBay used and when I tried to set it up I was stopped at the log in part on the app. I typed the default password in and it said it was wrong. I am assuming this means the previous owner did not reset it before shipping it out. I have sent him a message and am still awaiting his reply, but was wondering if there was a way to work around this if he does not respond back.
Any ideas or tips would be greatly appreciated. Thank you.
Rebecca
  • rebknell wrote:
    So, in order to use this I need a satellite? (as I got to the point where it was searching for one) Won't work without one?
    Great, i bought just this unit. They never mentioned in decription it needed this part to work. Sigh.
    Works fine without a satellite. You probably missed the cancel option.
  • Nenvermind - just found an article how to reset. Should have went there first. Sorry
    • rebknell's avatar
      rebknell
      • Mstrbig's avatar
        Mstrbig
        Master
