TrailgirlK2
Nov 18, 2018Follower
RBK20W - How do I set it up with same SSID as my current router?
Here's what I bought it for...
Just switched internet providers and the new router is too weak to get to my outdoor camera consistently.
I went to Best Buy, told them the issue and they said ...
ekhalil
Nov 18, 2018Master
- You have to switch off the wifi of your existing router and use only the wifi in Orbi.
- If your existing router is not bridged (provides DHCP functionality), then you have to set the Orbi into AP mode to avoid IP address conflicts.
