migsta
Dec 05, 2018Apprentice
RBK23 - additional satellites
I have an RBK23 system that I"m going to setup. With another RBK23, will I be able to add the additional 1 or 2 satellites to it? If I go with an RBK30, can I use the satellite that plugs into the ...
ekhalil
Dec 05, 2018Master
Yes, the official max number of Satellites is 3, but few have reported that they used up to 5 or 6 Satellites with no problem.
If I go with an RBK30, can I use the satellite that plugs into the wall with the RBK23.
Yes
How many satellites will the RBK23 support since it comes with 2 to start off and in what combination RBS20 or plug in ones?
The official max number of Satellites is 3, but few have reported that they used up to 5 or 6 Satellites with no problem. You can have RBS20 and/or RBW30 in any combination.
