migsta
Dec 05, 2018Apprentice
RBK23 - additional satellites
I have an RBK23 system that I"m going to setup. With another RBK23, will I be able to add the additional 1 or 2 satellites to it? If I go with an RBK30, can I use the satellite that plugs into the ...
Dec 05, 2018Guru - Experienced User
30 feet is recommended in between the base router and satellites to begin with depending upon building materials.
migsta
What about an RBK50 with two of the satellites from the RBK23 (so two RBS20's). Would I be downgrading the performance of the RBK50 system though since the smaller RBS20's have the lesses backhauld bandwidth or would the RBK50 setup perform to specs with each other at least? And, what would be the best positioning of the RBK50 and RBK23 satellites in a 3 story house where they main router needs to be located in the basement. WIll probably run them in AP mode though.
- ekhalilDec 05, 2018MasterThe RBR50 (the Router in the RBK50) will continue communicating with the RBS50 (Satellite in the RBK50) over 4x4 backhaul links, but over 2x2 backhaul links with the RBS20’s (Satellites in RBK23).
- FURRYe38Dec 05, 2018Guru - Experienced User
RBS50 satellites connect at 1700Mb while RBS20s connect at 867Mb. If you Daisy Chain the 50s with each other, then they still connect at 1700Mb. 30 feet is recommended in between them to begin with depending upon building materials.
