Imulji
Mar 14, 2019Guide
RBK23 as Access Point with a Switch
Hello everyone!
Another question!
I am upgrading my Internet and have a question for my setup. Is it possible to do the following:
Cable Modem -> Gigabit Switch -> 1 Router in AP a...
Mar 15, 2019Guru - Experienced User
If you have a managed switch, be sure to disable ALL IGMP protocols on this switch. Then your Orbi system should work well. Avoid any switches with Green Ethernet features.
Imulji wrote:
Hello everyone!
Another question!
Cable Modem -> Gigabit Switch -> 1 Router in AP and 2 Satellites (all ethernet backhaul through the switch).
Thank you for your feedback.
Imulji
Mar 15, 2019Guide
Thanks everyone for the suggestions.
The reason I want to use the Router as an AP is because the Modem is tucked away in the furnace room and there's really no use for the ORBI to sit in there - it would also place the ORBI Router right below an ORBI satellite which is upstairs.
I bought an Unmanaged Switch with no "green features" other than cable length power management. This one specifically: D-LINK DGS-1024D
Thanks for the advise! I will let you know how the install goes!
- FURRYe38Mar 15, 2019Guru - Experienced User
:smileywink:
- KSmoooveAug 05, 2019Aspirant
Imulji wrote:Thanks everyone for the suggestions.
How'd it go?
