Benjimcb
Apr 23, 2018Aspirant
RBK23 Ethernet Backhaul
Hey guys, I would like to buy Netgear Orbi RBK23 for my house. I have 2 floors and my ISP router os at the ground. I have Cat6 Ethernet cable that goes from the ground floor directly to the 2nd flo...
Benjimcb
So if its work I could put my Ethernet cable to the Ethernet port of my Orbi Router or I could put 1 Eth port of the Orbi router on an unmanaged switch and then the satellite of the 2nd to this switch too if I understand ?
And the 1st floor sat will run with fully wireless backhaul.
Am I right ?
Am I right ?
Apr 23, 2018Guru - Experienced User
Yes.
Also be sure to keep a 30-40 feet distance between the router and satellite(s).
