62cwil
Jul 07, 2017Aspirant
RBK30 kit
Lights on main unit and satellite after setup were blue and I got speeds of around 23mbps. After a while both lights went out but everything still works. Should blue light on both units stay on or is ...
peteytesting
Jul 08, 2017Hero
62cwil wrote:
Lights on main unit and satellite after setup were blue and I got speeds of around 23mbps. After a while both lights went out but everything still works. Should blue light on both units stay on or is it normal for them to turn off. Also does speed seem acceptable?
no lights = system is working normally after boot up
this is explained in the quick start guide
the speed however is quite slow
depending on
wifi client adapter speed
distance from router or sat
- 62cwilJul 08, 2017Aspirant
Thanks for responses. I am at a loss for help. I tried calling 7 times yesterday each time sayilng number 4 in q and 40 min wait time. Several times I waited over an hour and then hung up. Finally last night I got an answer and could hardily understand what was being said. The guy did tell me that the speed I quoted was very good, and from what I read this morning and your response it is not. Please help me. See below.
What do you mean by wi fi client adapter speed. What should I check.
when you day distance from router or satellite my router sits right next to my at&t Uverse Arris NVG589 router that I connected my orbi into the yellow internet port. Am I correct in connecting to the yellow internet slot or should I have connected to the ethernet slot. I am limited where I can put it. The satellite plug in is right behind my Smart TV located immediately below where the router is on the other side of the room. Can you give me idea how far to move it away to begin with so I will have an idea. What speeds should I expect.
- st_shawJul 08, 2017Master
The lights are supposed to turn off after initial power-on.
If you are not replacing another rotuer, then your Arris must be operating as a router. In that case, you should do the following to optimze your configuration and WIFI speeds:
1) Turn OFF the WIFI radio in the Arris NVG589. You will need to log into the Arris' web GUI to do this.
2) Set Orbi to operate in Access Point mode (not the default Router mode). You want to have only one router in your network.
A speed of 23 Mbps would be slow if you have an Internet plan faster than 23 Mbps and you are testing using a new tablet, phone, or laptop with 802.11ac WIFI.
1) What Internet speed do you have with AT&T?
2) On what device did you conduct the speed test that resulted in 23 Mbps (make, model, age, WIFI specification)?
- pwling88Aug 07, 2017Aspirant
It appears normal for the light to turn off. I was concerned about that earlier. The quick start guide does say it turns off. Check that your download speed is close to what you have subscribed (and paid for) from your ISP.
