62cwil
Jul 07, 2017Aspirant
RBK30 kit
Lights on main unit and satellite after setup were blue and I got speeds of around 23mbps. After a while both lights went out but everything still works. Should blue light on both units stay on or is ...
peteytesting
Jul 08, 2017Hero
62cwil wrote:
Lights on main unit and satellite after setup were blue and I got speeds of around 23mbps. After a while both lights went out but everything still works. Should blue light on both units stay on or is it normal for them to turn off. Also does speed seem acceptable?
no lights = system is working normally after boot up
this is explained in the quick start guide
the speed however is quite slow
depending on
wifi client adapter speed
distance from router or sat
pwling88
Aug 07, 2017Aspirant
It appears normal for the light to turn off. I was concerned about that earlier. The quick start guide does say it turns off. Check that your download speed is close to what you have subscribed (and paid for) from your ISP.
