Mike3963's avatar
Mike3963
RBK33 benefit of adding ethernet satellite RBS50
Bought RBK33 system one year ago (RBR40 router, two RBW30 satellites).  Noted the satellites do not have ethernet ports.  My work laptop is connected to satellite via WiFi.  My VPN connection to work often drops and reconnects.  Will adding RBS50 satellite (with ethernet port) and connecting to laptop via Cat5 cable help?
  • FURRYe38's avatar
    Possibly.
    What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
    https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
    What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
    Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
    https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
    One can add a RBS20, or RBS40v as well.
    • Mike3963's avatar
      Mike3963
      Thanks.
      current satellite RBW30 just updated firmware to 2.6.2.2.  Satellite is about 50 ft away from router.  Satellite is about 15 ft away from laptop.  Home is ~2300 sq ft.
      Laptop is connected at 5GHz but setting is auto.
      ISP is Spectrum.  Modem is Technicolor E31T2V1 which is DOCSIS 3.1 compatible.
      • FURRYe38's avatar
        You might try RBW a bit closer to the RBR. Maybe 40feet and see if this helps any...
