TimFung's avatar
TimFung
RBK40 connect to internet issue
Hi all,
I have a Orbi RBK40 connected to satellite which placed at the next next room. Most of the time, I have no problem on using the WiFi. However, sometimes while I am surfing the internet with mobile/ computer, the network would suddenly disconnect and require few minutes to connect again automatically.
May I ask what’s the problem and solution?
Thank you!
  • need more info
    how far is the sat from the router?
    color on the router and sat?
    how far is the mobile/ computer (laptop?) from the sat or router?
    • TimFung's avatar
      TimFung
      Amend: satellite at next room
      Sat & router are 7 feet apart( through 1 wall).
      Both router & sat show white light on the round top.
      I’ve installed the orbi app, the router is green light while sat is orange.
      When it is good, I can use mobile/ computer all around at home (4-5meter away from router/ sat is ok). Sometimes it just “suddenly“ interrupt the internet connection and reconnect after few minutes (may be 7 feet from sat).
  • FURRYe38's avatar
    What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
    https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
    https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
    TimFung wrote:
    Hi all,
    Thank you!
