Ryan1919
Sep 01, 2018Tutor
RBK40 Download Speed Slows Down After 5 Days
I have the RBK40 Router with two RBS20 satellites connected to my home wifi. I'm using it in router mode and not AP mode..Every 5 days my Internet speed drops from around 200mbps to around 40mbps..The satellites are not affected and I still get over 200mbps on each satellite. My satellites are connected through wireless backhaul. I can reboot the the system and every thing will go back to normal for another 5 days..What could be causing this? Memory leak of some sort) I have not changed any of the default settings except for disabling the daisy chain option. I am running the latest firmware (2.1.4.16)
Internet speed or wifi speed?
Here's an off the wall suggestion, the next time this happens, don't reboot, go into the GUI and clear out the logs.
There is a manual for the Orbi WiFi System somewhere at the end of this link:
>>>> Orbi RBK50 | WiFi System | NETGEAR Support <<<<
Check the bit View and Manage Logs of Router Activity.
I mention this because someone else had some some experiments with a different router that showed wifi issues growing over time and found that full logs were behind it.
This may have nothing to do with what you see, but the experiment would be useful. If it works then you know what to do, turn off the logs or find a logging regime that works without causing a slowdown.
- Ryan1919Tutor
Thanks for the reply. When I said "Internet speed" I meant the speed I'm seeing while connected to wifi. All of my devices are connected via wifi and I don't have anything hardwired as of now.
I will give your suggestion a shot when i see my speeds start to drop again and will update this tread when I do. I was reading that the logs hold a maximum of 250 entries so maybe when they get full is when I see the speed drops. In the log section of GUI there are total of 8 different options I can log. If clearing them fixes the issue which ones would you suggest that I leave checked afterwards. Do I need any of them checked? I'm not very technical, so when I look at the logs it means nothing to me. Would I need them for anything other than me looking at them?
Ryan1919 wrote:
Do I need any of them checked? I'm not very technical, so when I look at the logs it means nothing to me. Would I need them for anything other than me looking at them?Your call really. The logs are there to help you to diagnose problems.
You could consult them to see if they show anything related to your wifi issues.
I have my logs set up to email them to me daily. This seems to empty out the log.
Another thing you could try would be to factory reset the Orbi router.
What FW is currently loaded?
What is the Mfr and model# of the IP modem the Orbi is connected too?
What is the Mfr and model# of the ethernet switch if one is in the configuration.
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
Are your speeds tested wireless or wired?Was a reset performed after the FW update?
- Ryan1919Tutor
1.) FW version (2.1.4.16)
2.) Arris Surfboard SB6183 Modem-If I hook up directly to the modem I get my full download speed. After I saw my speed slow down on the router I hooked my computer directly to the modem to see if the problem was coming from my isp.
3.) Home Square Feet= 2107
4.) Both satellites are almost exactly 30 feet from the router. My satellites are not affected..I'm only seeing the speeds slow down on the router on the 5th day after I reboot everything. It happens on the 5th day every time..If I reboot the system the speeds go back to over 200mbps for another 5 days.
5.) My channels are set to auto. I downloaded Netspot and none of my neighbors are on the same channel as me. I have 2 houses nearby.
6.) I've already tried disabling those options but it did not affect anything.
7.) My speeds are tested wireless.I get over 200mbps wirelessly until the fifth day and then anything connected to the router will drop to about 40mbps..Anything connected to the satillites after the fifth day will continue to see speeds over 200mbps wirelessly. After I reboot the speeds on the router will go back to over 200mbps wirelessly.
8.) There has not been a firmware update since I bought the system that I'm aware of.
I'm going to try clearing the logs next time my speeds slow down again per a suggestion from another person on this thread.
"5.) My channels are set to auto. I downloaded Netspot and none of my neighbors are on the same channel as me. I have 2 houses nearby." Can't be on same channel as this will cause interferences. Lets try manual channels, 1, 6 or 11, which ever one is less used by nieghbors. Try any channel on 5Ghz.
- Ryan1919Tutor
On #4 I meant to say the speeds slow down on the 5th day every time and after i reboot the speeds will resume to over 200 mbps second again.
:smileywink:
- Ryan1919TutorToday was the 5th day and my router speeds dropped to around 40mbps again while connected wirelessly. My devices connected to the satellites were still seeing full download speeds at around 212mbps connected wirelessly. I went ahead and wired my computer in via Ethernet cord to the back of the router and I got the full download speed of 217mbps. So basically something is happening every 5 days that causes my download speeds to drop to around 40mbps for any device that is connected to the router wirelessly. My satellites are not affected and when I’m hardwired into the router it is not affected. Only devices connected to the router wirelessly are affected. I’ve done all the normal troubleshooting: Disabled mu-MIMO, daisy chain, and beam forwarding. I’ve also cleared my logs daily. I haven’t tried a factory reset yet but will that really help anything? The only thing that will reliably fix it is doing a reboot. Any ideas on what this could be? It’s really frustrating that I spent this much money and have to baby sit the router and reboot it every five days for it to work right. Could I possibly have a bad router, or do you think this something that a firmware update could fix?
Yes, lets do a factory reset on the router and set up from scratch. IF the problem continues after than then the router needs to be RMAd and replaced.
