sespencer's avatar
sespencer
RBK40 dropping connection repeatedly
RBK40, firmware v2.1.4.16
I bought the RBK router and satellite in May this year.  I set it up, switched it to AP mode, both base and satellite working well, had blisteringly fast wifi and thought it was great.
Then the network drops started.  I spent ages trying to work out if it was my fibre connection, my router (then a Draytek 2860) or the Orbi AP set up.  Finally got my ISP to send me graphs of monitored connection, it showed drops so I switched out the router for my previous/backup one - a Zyxel VMG1312-B10D - and the ISP graphs stopped showing drops.  Thought woo-hoo...
But the drops continue, wifi keeps disappearing for a few minutes then reappearing.  Everything loses wifi, upstairs and down.  It's the Orbi dropping the connection for no reason.  Occasionally, when I've been bothered to go and look, the orbi has rebooted itself, but sometimes not and I have to unplug it and plug it back in to get the wifi back.  I browsed these forums and tried different channels, moving the satellite (no wifi at the top of my house without it) disabling various elements (daisy chain, mu-mimo, 20/40 coexistence, fast roaming, beam forming), factory reset and repeat, everything I could find suggested on the forums.  And still it drops.
Yesterday installed network monitoring software on my mac to monitor the wifi connection continuously - and today it showed six drops lasting between 3 and a bit over 15 minutes.
This is pants.  It's over four months of mucking about and it's still not stable.
Is there an older firmware that is more stable?  This is an expensive piece of kit that it's taken me this long to establish that nothing I can do will make it stable... what next?
  • FURRYe38's avatar
    How is the Orbi connected to the main host router? WAN or LAN port? If WAN port, try the LAN port on the Orbi base.
    Does your router have any kind of IGMP protocols? If so, might try to disable ALL IGMP protocols on the router.
    What is the distance between the Orbi base and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
    • sespencer's avatar
      sespencer
      Okay, done.
      Done.
      About 1050
      About 30 feet, old house, thick walls.
      11 on 2.4, auto on 5 GHz (but no other 5 Ghz found nearby)
      3, all on Channel 6
        sespencer
        All changes made, drops continue.  Six drops lasting between 2 mins 16 secs and 2 mins 46 secs... and a few longer - one around 5 mins, and one 12 mins.  All in 24 hours.
