rdun72
Jun 08, 2018Tutor
RBK40 inexplicable boot behaviour with ethernet
Hi,
My setup is working well but I can’t explain a couple of things…
BT HomeHub routing, RBR40 (AP) and an RBS40 connected directly to the HH via ethernet i.e. star with HH at centre, not...
Jun 08, 2018Guru - Experienced User
The RBS needs to be connected to the RBR directly, not thru the HH ISP modem/router.
- rdun72Jun 08, 2018TutorSeems to work ok if I use the LAN port. Also the Ethernet bachaulbpage shows a star as a supported config. Reading around a bit more it looks like I should connect to the LAN port. But that leaves the question of why the magenta light?
As I say everything works great....
