rdun72
Jun 08, 2018Tutor
RBK40 inexplicable boot behaviour with ethernet
Hi,
My setup is working well but I can’t explain a couple of things…
BT HomeHub routing, RBR40 (AP) and an RBS40 connected directly to the HH via ethernet i.e. star with HH at centre, not...
Jun 08, 2018Guru - Experienced User
Yes you have to use the LAN port between the Orbi router and satelilte.
After getting the Satellite connected, try a reboot or power cycle the satellite and see what happens? Should turn BLUE.
How far away is the satellite from the router? Could be some interferences maybe from neighboring wifi.
