YabbadabbaDoooo's avatar
YabbadabbaDoooo
Apprentice
Jun 28, 2017
RBK40 Issues Resolved with latest firmware 1.11.0.20
I have the Orbi RBK40 with one satellite.  I was experiencing the various issues described in other threads with instability.  The signal would randomly drop, speeds fluctuated wildly from one second to the next, internet access woud drop, etc...  I was just about to return it but the recent Firmware update to 1.11.0.20 seems to have "fixed" everything. The release notes state it was for Wifi Connectivity bug fixes for the RBK40 series.
Is anyone else with the RBK40, who was having similar problems, notice that the system is working better than ever with the new Firmware?
It has been 4 straight days now and I have had zero problems.  I am getting max speeds both near the router and satellite.  I want to find out if others are having the same positive experience before I cancel returning it.  At last it appears to be working as it was advertized.  I just need to know if it will last.
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Thank you for the feedback on the latest firmware that it did fix the issue that you are having.
    DarrenM
    • YabbadabbaDoooo's avatar
      YabbadabbaDoooo
      Apprentice
      Just to be clear, I posted this to see if other users have experienced resolution of the many stated problems this system has had since it was released.  I had short windows of time when the system was stable after I made some minor changes to the Router, or as in this case, new firmware came out.  Only to be disappointed after a week or so when the problems began again.
      I do not want to return the product if this latest Firmware update truly fixed the problem but I can't wait too long if I am going to return it.  I hoped others would post their experience on this thread to give me some reassurance that it is in fact permanently resolved.  The majority of posts related to the Orbi seem to be related to the RBK50, which is to be expected since it has been on the market longer. I don't know how to get more visibility to this thread.  Perhaps as a moderator you can help get more visibility on this thread.
      • Doug-48051's avatar
        Doug-48051
        Luminary
        I have RBR50 setup and FW. I am getting drops of SAT through out the day, roughly 3 hours a part. Outages do seem short in nature.
  • DarrenM's avatar
    DarrenM
    Did you try a factory reset when going to the new firmware?
    DarrenM
      YabbadabbaDoooo
      Apprentice
      Why would I have done a factory reset before updating to the new firmware?  That makes no sense.  When my system Auto Updated to 1.11.0.20 everything was perfect.  When you all sent out 1.12.0.18 it created more problems that at any time I have owned this piece of junk.  I successfully rolled back to 1.11.0.20 but it has only marginally improved things. So, as soon as I have an extra hour, I have no choice but to factor reset and try installing 1.11.0.20 again.  If Orbi owners are going to have to do factory resets every time there is new firmware, that is simply unacceptable.  I hope that isn't the case or I will find every place that sells the Orbi and give it the poor review it deserves.  Fix it Netgear.  I have wasted far too much of my time on a system you should have never sold with all of these bugs.
      • DarrenM's avatar
        DarrenM
        There are issues with the latest firmware for the RBK40/30 and our engineers are working on it so you will want to go back the last firmware until the latest firmware is released again.
        DarrenM
