Sharknado3's avatar
Sharknado3
RBK40 Orbi connectivity issues (1000Mb)
Device had a  white ring light on the satelite and is constantly dropping connection to no internet.  The cable company has been out and verified the lines are correct.  It has been working fine with few hiccups for 6 months.
It took two commplete full rests to get working and stopped working within hours again.
I'm still under the year warranty, but customer service refuses to help with the device since I'm past 90 days.  How am I supposed ot get warranty replacement if I can't talk to anyone besides a chatbot call center who wants to sell a service plan.
I have to say Netgear used to be a premium company, but this leave a bad taste in my mouth and my in-laws who are using this device.  How on earth are they supposed to trouble-shoot a device like this?
I can answer questions, but the product is 3 hours away in the home of your average user, so short of here is an easy answer, I really need to have the device replaced.  A working device shouldn't break itself by the way.  TIA.
  • FURRYe38's avatar
    Is the Orbi system operating in Router or AP mode?
    What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
    Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
    • Sharknado3's avatar
      Sharknado3
      It is in router mode, probably 30 to 40 feet in distance apart.
      No clue on the cable modem brand.
      How is one supposed to replace a device under warranty if defective or Netgear refuses to let you talk to anyone? I'd like to hear that answer, but I will certainly see if I can walk my 70+ year in laws through these suggestions.
