keung006's avatar
keung006
RBK40 upload movie on youtube by wifi
The youtube upload speed through is extremely slow, it takes 70minutes for 1GB movie. But the speed test shows that the upload speed is 65Mb/s.
But when I use 4G mobile network to upload the same file, it takes 15 minutes only.
I also used wired LAN wire orbi netwoek to upload the movie, it take 2 minutes to complete uploading process.
Can you help to solve this issue???
  • FURRYe38's avatar
    What wireless device are you using to upload the file?
    Which frequency is the device connected too? if 2.4ghz, might be why.
    What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
    Set WPA2 and AES on the Orbi router and apply and reboot both router and satellite.
    MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
    • keung006's avatar
      keung006
      I have followed your instruction one by one. It still doesn’t work. But when I the 5.0Gz from 36 to 40,44. The upload is faster, I finish upload within 10mins. But when I upload another movie, the upload speed remain very slow...
      • FURRYe38's avatar
        Interesting that changing channels helps however only for the one upload then slows back down.
        I think NG support needs to review this.
        Christian_R
