Forthay
May 29, 2018Tutor
RBK43 or RBK53
Hi,
I tried a RBK53 with two satellites and was very impressed except some devices reported less than a 100% signal strength in certain area's of the house. The router is in the centre downstai...
May 29, 2018Guru - Experienced User
Possible that you might have some signal degradation due to your building materials...nature of the beast espeically on 5Ghz.
I have mine at 40feet in between however just wood and dry wall materials. Nothing brick and stucko.
You may want to try moving the satellites a bit closer to the router, say 5 feet and check.
