SoNCSU95
May 26, 2022Aspirant
RBK43S firmware update seems to have crashed everything
Haven’t had a problem in two years. Have tired everything. Got to point of trying to download firmware from netgeat.com and using TFTP. Extract files and “disk image… is corrupt”. This happens on a PC...
SoNCSU95
While traveling Tuesday, I notice my phone was not connecting to my Phillips Hue App nor my garage door opening app. Son confirmed wIFI was working and respective hubs were still connected. When I got home last night, WIFI was gone. Router cannot be found via the app. Notice of updated firmware being available but cannot update without being connected to router. Flashing white light ultimately turns in to solid magenta light.
May 27, 2022Guru - Experienced User
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
