AmanSingh
Feb 06, 2020Tutor
RBK50 - Slow Wifi Upload speed
Hello, I got New Orbi mesh system in September 2019, it had an issue with Slow wifi upload speeds since day 1. After months of hassle with support i was issued a new Orbi system. The bew Orbi syste...
Let start with questions, yes you may have done them however for us, we don't know what you did exactly.
What ISP Speeds UP and Down do you pay for?
https://kb.netgear.com/19668/Link-Rate-and-Transfer-Speed
Distance will vary and as connection rates. You can always have an expected max connection rate with the RBR or RBS if your device is at a distance along with building materials will also play a role in this as well. If wired connections are good then there may just a wireless issues that needs to be figured out.
What WiFi devices do you have?
GerryGoa wrote:Hi,
Sorry if I seemed harsh, but i'm really frustrated. This forum is great and tried all the suggestions posted here, but nothing worked. This mesh system is not cheap and if I paid 100$ I would probably keep it and not even bother. But I paid 500$.
The only possible issue now is probably the Fibre optic cable not tapped correctly (from what I read in the forum).
I will try with some other mesh network perhaps if possible.
After trying all the suggestions here, I tried calling support, but no one picks up, not sure if it's 24x7 support as I called at 3am. I can't do it during the day cos with Covid we're all working from home and I can't test it during the day.
Just inquisitive , what's a good range for different devices, laptop, cell phone and tablet, all through wifi. Wired connection is fine.
Hi FURRYe38,
I posted my wifi details in a new post, any help would be appreciated. Didn't want to hijack Aman's post.
https://community.netgear.com/t5/Orbi/Orbi-RBK50-Speed-Problems/m-p/1936594#M96265
Thanks in advance,
Gerry
Seems the post didn't make it or something happend. Please repost again and we'll help you figure this out with you.
GerryGoa wrote:Hi FURRYe38,
https://community.netgear.com/t5/Orbi/Orbi-RBK50-Speed-Problems/m-p/1936594#M96265Thanks in advance,
Gerry
Here it is again, the link works, I tried it, not sure why you can't see it.
But here it is again.
I seem to be getting slow wireless Internet connection speed, wired is fine. Cell phones still seem very slow. I only managed to get high speed the first day or 2, don't remember exactly how much, but I was satisfied, not any more.
I have a 3400 sq. ft home, 3 levels. Bell Home Hub 3000 router is in the basement. Construction is pretty standard, more open concept and walls are drywall. I have cat5e cabling from the basement to the office and family room on 1st level and another cable running up to the landing area on the 2nd level.
My old system includes 2 TP-Link Archer C7 access points. But wifi sucks lately (<5mbps sometimes) in the last 6 months or so.
Got the Orbi RBK50 for better wifi and mainly faster internet speed.
I connected the Orbi RBK Router to the Office on 1st level. The Satelite to the landing area. It will be about 30 feet apart or less. I have also tried connecting the Router to the Family room with similar speed. All speed tests were run with ookla.Settings info:
Firmware V2.5.1.16
WMM enabled for 2.4(Auto) & 5 Ghz(Ch:48)
Enable Daisy-Chain Topology
Enable Beamforming
Enable MU-MIMIO
Disabled Fast Roaming
Disabled IPv6
Router Mode
Disabled Armor
Disabled 20/40 MHz Coexistence
All speed tests were done late night with no other devices connected.These are the speeds I get (download / upload), I used a laptop.
Bell Home Hub 3000 Router - 1.13 gbps / 824 mbps
TP-Link Archer C7 Router - 812 / 806
Wired directly to Bell router - 843 / 816
Wired to Orbi RBK50 - 725 /735
Orbi App on cell phone - 545 / 813
Wireless connected to Orbi Router(2 feet from router) - 256 / 257
Wireless through Huawei phone(2 feet from router) - 45 / 34Living Room - 10-20ft from router -
Laptop - 240 / 267
Cell phone - 47 / 8Family Room - 25-35ft in between router and satellite
Laptop - 181 / 166
Cell phone - 36 / 14Kitchen - 35-45ft between router and satellite
Laptop - 200 / 158
Cell - 7 / 5mbps2nd level
Landing aread - 3 ft away from satellite
Laptop - 217 / 252
Cell - 42 / 32Bedroom 1 - 25 ft away from satellite
Laptop - 213 / 257
Cell - 38 / 13Bedroom 2 - 40 ft away from satellite
Laptop - 230 / 357
Cell - 17 / 8
