rinku2012
Mar 05, 2018Tutor
RBK50 access point with R8500
Hello, Recently i bought RBK53 and returned it due to disconnection issues. Presently i am staying on 3 floor town home. I have R8500 router in my 2nd floor and i get decent internet everywhere ...
Mar 05, 2018Guru - Experienced User
Either one would work. If you used the Orbi in AP mode, you would disable the R8500s wifi radios.
rinku2012wrote:Hello,
Presently i am staying on 3 floor town home. I have R8500 router in my 2nd floor and i get decent internet everywhere in my house.
I have 2 options as mentioned below
1. Buy another R8500 Router and place it on 3rd floor in one of mybedroom which has Lan connection and make the R8500 Access point
2. Buy RBK50 and place it on 1st floor and 3rd floor, connect it via Lan and make it into Access point and use Ethernet Backhaul.
Can you guys suggest me any option so that i can purchase the router
Thanks
- rinku2012Mar 05, 2018Tutor
what if i buy another R8500 router and use it in AP, should i still disbale wifi radios in my main router ?
- FURRYe38Mar 05, 2018Guru - Experienced User
No
rinku2012wrote:what if i buy another R8500 router and use it in AP, should i still disbale wifi radios in my main router ?
, you can leave it's wireless radios going while you have the 2ndary AP going as well. Just need to make sure that the first routers wifi is set for channel 11 on 2.4Ghz and say 48 on 5ghz, then set the 2ndary AP for channel 1 on 2.4Ghz and 149 on 5ghz. Channel separation is needed between these two wireless sources.- rinku2012Mar 05, 2018Tutor
Thanks. Which one do u suggest me. R8500 or Orbi RK50 ?
