danielgass's avatar
danielgass
RBK50 Access to my home network from internet (doesn't work)
Hello, My LAN network is in the range 192.168.1 and the LAN network between the RBK50 and my BOX to internet is in the range 192.168.0. If I try to access from a PC (192.168.0.3) to a PC (192.168.1...
  • st_shaw's avatar
    Aug 10, 2017
    danielgass wrote:
    Hello,
    If I try to access from a PC (192.168.0.3) to a PC (192.168.1.240) I get the message "Destination Host Unreachable".
    How can I configure the RBK50 to allow access ?
    Have you an idea ?
    Many thanks for help.
    Dan
    Sounds like your BOX is a router and you are also running Orbi in router mode.  Two routers will cause the issue you are seeing.  You have three choices:
    1) Configure port forwarding on both routers. Not recommended.
    2) Bridge your BOX so it does no routing. Port forward on your Orbi.
    3) Run Orbi in access point mode, so Orbi does no routing. Port forward on your BOX.
