jschweiss
Sep 27, 2019Follower
RBK50 accident, satelite is dead
In short, I knocked my RBS50 satelite off its perch last night and it seems very dead (no lights, no connection, no response). That leaves me with my lone RBR50. The only items that come up in my s...
CrimpOn
Sep 27, 2019Guru - Experienced User
jschweiss wrote:Would I be able to step down to an AC2200 satelite or do I need to stick with AC3000?
Any Orbi satellite will function with the RBR50 router. They will not achieve the same maximum backhaul rate, but they will work.
As you have noticed, the issue seems to be finding a vendor that sells satellites by themselves.
