Latitudes33
Sep 25, 2018Aspirant
RBK50 and RBS50: constantly disconnecting and dropping internet
Running on 2.1.4.16.
I have an Orbi RBK50 connected through wired backhaul and an RBS50 connected wirelessly on my network. The system works great periodically, but on some days it constantly ...
Blanca_O
Oct 07, 2018NETGEAR Employee Retired
Hi All,
There is a new firmware released for RBK50. Kindly update the firmware to 2.2.1.210.
https://kb.netgear.com/000060273/RBR50-RBS50-Firmware-Version-2-2-1-210
Blanca
Community Team
Ken167
Oct 11, 2018Aspirant
Dear Blanca,
No more pushed "automatic" updated please.
Once my R50 was updated to V2.1.4.210 automatically few days ago, it became unstable again, constantly disconnecting and dropping internet. At lease 2-3 times everyday. It took me hrs to downgrade it back to v2.1.4.10 after reading https://community.netgear.com/t5/Orbi/Disable-auto-update-of-orbi-firmware-additional-steps-needed/td-p/1575772.
R50 back to work again after downgrade !!!
- FURRYe38Oct 11, 2018Guru - Experienced User
The system may upgrade again since NG seems to be pushing this version out.
One thing you should try if this happens, download the FW files and manually install them, then do a factory reset and set up the system from scratch:
If you updated to recent FW v.210, try enabling Daisy Chain. Some have mentioned that this seems to be working in reverse order, enabling means disabled actually. So try this out as well.
https://community.netgear.com/t5/Orbi/Firmware-2-2-1-210-and-connection-problems-Skybell/m-p/1649275/highlight/true#M43001
Ken167 wrote:
Dear Blanca,
