VictorLion70
Jan 16, 2019Initiate
RBK50 connection to TPG HFC NBN
I have a TPG HFC NBN connection in Sydney
It is connected to an ARRIS DM8200 modem
I am trying to connect the Netgear Orbi RBK50 router as I want its parental controls
I have updated the firm...
- Feb 02, 2019
Thank you to Scorptec for providing this solution, which works.
Go to the Router menu:
1. Advanced
2. Advanced setup
3. VLAN
4. Enable VLAN
5. Tag group, set VLANID=2 and name=internet
VictorLion70
Feb 02, 2019Initiate
1. Advanced
2. Advanced setup
3. VLAN
4. Enable VLAN
- FURRYe38Feb 03, 2019Guru - Experienced User
Glad it working now. Mark your thread solved so others will know for future reference.
1. Advanced
2. Advanced setup
3. VLAN
4. Enable VLAN
