whynotme's avatar
whynotme
RBK50 drops to 30Mbps every couple of hours, must reboot to fix
Just installed RBK50 Orbi Triband Mesh AC3000 system and after a few hours, the speeds drop to below 50 Mbps and the only thing I can do to fix is reboot.  I've now rebooted my system 5 times in 24 hours.  I'm running the latest firmware 2.5.1.8 and Netgear support had me set the MTU to 1492.  It was set at 1500.  Right after a reboot and for a few hours after I can get close to 600Mbps on my phone (Galaxy S10).  Then it drops back down below 50Mbps after 2-3 hours.  Anyone see this before and have a fix?  Not sure what's happening to make it suddenly lose speed like that.  Thanks in advance.
  • Anonymous's avatar
    Anonymous
    I'm going to bet the FW 2.5.1.8 is your problem.  When/how did you get it?
    • whynotme's avatar
      whynotme
      It updated automatically when I installed the system yesterday.
      • whynotme's avatar
        whynotme
        I should add that I'm running a brand new CM1150V modem.
  • FURRYe38's avatar
    Has a factory reset and setup from scratch been performed since last FW update? I would do this if you haven't.
    Set the MTU value back to 1500, 1492 or less is for DSL ISP services. Cable services use 1500.
      Anonymous
      :smileysad:
