Hanny_1
Apr 28, 2020Follower
RBK50 initial connect
I bought my Orbi last year and was unable to connect it. It's now been several months, so I no longer have access to support. Don't ask why; I regret it now.
I keep trying to connect following the instructions, but I get the message Unable to join the network "ORBI95". I'm not very tech savvy, but I can follow directions. I have XFinity wifi.
What should I do?
1 Reply
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too? If the ISP modem has a built in router and wifi, This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktopUse a wired PC connected to the RBR and a web brower to access the RBRs web page at 192.168.1.1 or orbilogin.com
