Halewafa
Jun 14, 2018Guide
RBK50 Initial Setup Question with Arris SB8200
Hi Guys,
I searched for a bit and couldn't quite find the answer I was looking for (or maybe I did, but the lingo was over my head). I just got the Orbi RBK50 3-pack and I'm getting ready to set it...
Jun 14, 2018Guru - Experienced User
The two ports on the SB modem is not for LAN devices and only one port can be used. Those two ports are for link aggregation when and IF Arris decides to implement it and if ISP will support it.
You can keep the main host router on the main floor level which is preferred if you have a long enough cable from where the ISP modem is currently place. IF it's down in the basement as well.
You can run ethernet back haul between the main router and satellites. Set them up first via wireless then connect the ethernet cable to the back of the satellite. Give 5 minutes then the top led should turn BLUE.
Besure your using good quality LAN cable, CAT6 recommended and if switches are needed, use non managed switches.
Halewafa
Jun 15, 2018Guide
Awesome, thanks for all the great information! I just set up the Orbi today, initially wasn't impressed (the speeds were slower than the TP-Link router it replaced), but after about 30 minutes speeds were much improved. Getting around 450 mbps down on WiFi at home router, 350 mbps in the basement upstairs, haven't tried with ethernet yet.
Question for you though, is there a specific ethernet port I should plug into the satellite from the home router? None of them are labeled for internet.
Thanks!
- FURRYe38Jun 15, 2018Guru - Experienced User
The Yellow marked port in back is always for Internet or ISP Modem connections. All the other ports in back, the Black ones are LAN ports. Any of them will work.
